Extracting raster values according to different classes
9852
15
07-01-2015 12:39 PM
DitlevReventlow
Hey everyone.
I have a raster dataset (bshl_112p_srf) that I want to split up according to the classes that I have defined.
These classes are defined as:
158-535
535,0000001-686
686,0000001-1473
I have tried to use raster calculator to do this but it doesn't work. To extract the first class I tried to type:
Con("bshl_112p_srf" <= 535,"bshl_112p_srf")
, however I get an error for this expression.
What do I do wrong? Also, how would you extract the middle class (where you both need to have a <= and >= ).
Would it be something like:
Con("bshl_112p_srf" >= 535,0000001 & <=686,"bshl_112p_srf")
Thank you!
best regards
Ditlev Reventlow
JayantaPoddar
An additional parenthesis when using &.
like
Class 1 =  Con(("bshl_112p_srf" >= 158) & ("bshl_112p_srf" <= 535), "bshl_112p_srf")
Class 2 = Con(("bshl_112p_srf" > 535) & ("bshl_112p_srf" <= 686), "bshl_112p_srf")
Class 3 = Con(("bshl_112p_srf" > 686) & ("bshl_112p_srf" <= 1473), "bshl_112p_srf")
Hope this will work
Think Location
DitlevReventlow
It works, thank you so much!!! Very gratefull!
DanPatterson_Retired
For your immediate concern... you should not be working in folders that contain a space...
In the future, you might want to look at Extract by Attributes—Help | ArcGIS for Desktop
​since you have the spatial analyst.  This will produce simpler approach and can be easily be put in a loop
DitlevReventlow
Okay I have done all my modelling working in this folder. What could the effects of it be?
IanMurray
Honored Contributor
I see nothing wrong with your first statement, works fine for me.
Your middle class would need to be
Con("bshl_112p_srf" >= 535,0000001 & "bshl_112p_srf" <=686,"bshl_112p_srf").
Are you wanting to split them into three seperate rasters or truly make a new raster with 3 classes in it for each range with the same value?  If so you might want to check out the Reclassify Tool.
ArcGIS Desktop
DitlevReventlow
Thanks for mentioning the reclassify tool. I had not tried to use it yet. I don't think I need it in this case though. It is probably more usefull for me to have 3 individual rasters.
