Extract.save error?  Cannot save file
1654
07-11-2013 08:44 AM
MaryM
Please help, I get an error? Error is that it cannot save?  The odd thing is it runs if I do not set it up as a toolbox and put the input name of the raster seperate from the folder name?  Any ideas or is that how it has to work?
#Extract by Attributes for all hubs
#by rangermry, 7-11-2013 using Python 2.6.5
import arcpy, os
from arcpy.sa import *
#Check out Spatial Analyst Licesne
ras=arcpy.GetParameterAsText(0)
saveSpace=arcpy.GetParameterAsText(1)
i=0.0
while i <= myRaster.maximum:
    i+=1
    inSQLClause="Value="+str(i)
    num=str((str(i)).split(".")[0])
    attExtract=ExtractByAttributes(ras,inSQLClause)
    attExtract.save(os.path.join(saveSpace,"Value"+num))
MaryM
Oops, made mistake for input parameter should be (1) for the second one.
MaryM
I am trying this now, maybe it will work:
import arcpy, os
from arcpy import env
#User inputs
#Derived inputs
rasName=str(ras.split("\\")[-1])
rasWkspce=ras.replace(rasName,"")
env.workspace=rasWkspce
i=0.0
    i+=1
    attExtract=ExtractByAttributes(rasName,inSQLClause)
