Extract Multi Values to Points NOT WORKING!
22919
20
04-29-2012 05:16 PM
KevinWiley
I am trying to use this tool, but it isn't working correctly.  I'm trying to extract values from multiple rasters to a set of points.  I run the tool, and it always creates the new fields in the point attribute table; however, it never populates those fields with all the values.  Sometimes, it's no values at all. Sometimes, it's one out of five raster fields. Sometimes, it's three out of seven. But so far, I've never had all the new fields properly populated with values. Also, if I use the Extract Values to Points tool, and go one raster at a time, that tool works fine.  But the multi tool would be far more convenient, if only I could get it to work.  Is this tool just buggy, or do I need to do something differently?  Please help!
NickMulgan
Using 10.6.0.8321 I had the symptom that the tool said it worked but produced nothing.
Reprojecting the point data to the same coord system as the raster fixed the problem.
