Extract maximum values from raster by polygons
16942
11-15-2013 12:51 PM
toddsams
I have a continuous raster and a set of polygons that overlap the raster.
Does anyone know of a method to:
1) identify the maximum value of the raster within each polygon
2) extract the cells associated with these maximum values and store as a separate raster (or points)
Any suggestions are greatly appreciated.
XanderBakker
Esri Esteemed Contributor
Hi Todd,
Try this:
  • Perform a Zonal Statistics (using the polygons as zones, the raster as values and MAXIMUM as stistics type)
  • Calculate a boolean raster with: ValueRas = MaxRas (value 1 will indicate those pixels locations with maximum value in polygon)
  • Use the SetNull to obtain a raster holding only the maximum values at the locations you're interested in and rest NoData: OutRas =  SetNull(BooleanRas, MaxRast, "Value = 0")
  • Convert this "OutRas" to points
Kind regards,
Xander
XanderBakker
Hi Todd,
Try this:
Kind regards,
Xander
FatihDur
Just for the references, there is a step-by-step guide to very same process in How To: Create points representing the highest or lowest elevations within polygon features
