Extract by Mask Rasters don't line up with originals
842
10-21-2010 02:44 PM
KarlZimmer
Hello all,
I am working with some Landsat imagery that I need to extract certain areas of the raster. I've tried extracting by a polygon mask. The extraction works fine but for some reason the output raster pixels no longer line up directly with the pixels from the original raster. Similary, if I use reclassify to export specific pixel values, these output rasters don't line up either. The shift is quite small, about half a pixel, but I can't figure out why it is doing this. Any ideas? Both the polygon mask and Landsat raster have the same projection so I don't see it being a projection issue.
Any help would be greatly appreciated!
Cheers,
Karl
RobertBerger
Hi Karl,
There is an environment setting called snap raster which should also help. The tool help says that it takes the parameter.
Robert
ThuPhan
Hi all,
I am also experiencing this problem, though I've check in the environment setting for raster analysis and trying a couple of combination and it still shows the same result. Could anyone in the forum help me to explain why it can happen? I am currently running ArcGIS 9.2 and 9.3.1. Thank you very much for your help.
SimonLee
Hi guys. I know this is a very old thread but I met the very same problem when extracting some grid cells using a mask. I found a workaround solution somehow. Try "Extract by polygon" instead of a mask, which works great for me. I'm using arcgis v10. Hope it helps. Thanks
SimonLee
Well yes, "Snap Raster" works great. 🙂
