Error in calculating Area Solar Radiation
2428
12-09-2010 07:42 AM
michelrapinski
I am trying to calculate Area Solar Radiation (Spatial Analyst -* Solar Radiation - Area Solar Radiation) from the Canada3D DEM map.  I always get the following error:
ERROR 010016: Error in calculating horizon and radiation.
ERROR 010005: Unable to allocate memory.
Anybody might know how I can fix this problem?  Or if there is a better DEM map I can use to get Solar Radiation data for Northern Quebec (James Bay and Hudson Bay region)
Thank you,
Michel
DanPatterson_Retired
you are probably trying to cover too big an area, check the help topic, it is not designed to do broad regions covering many degrees of latitude
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Area_Solar_Radiation/009z000000t500000...
SarahMcCabe
Those two errors happen when the points and the elevation model are not in the same projection.
