Distance calculation error
1579
02-03-2011 02:38 PM
JoeLenon
Hello,
I am trying to calculate straight line distances from a raster layer but i keep getting errors.
In the spatial analyst toolbox, i clicked Spatial analyst>Distance>straight line.
When i click ok i get an error message:
ERROR 010328: Syntax error at near symbol NEW-LINE
ERROR 010267: Syntax error in parsing grid expression
I've been have been having this error for a week or so and i don't see a way out.
Some people suggested to me that i had to remove spacings from file directories but that didn't help me solve the issue.
Please, any tip would be welcome.
Thank you
DanPatterson_Retired
detailed specifics are needed..aka source files...destination location and anything else you can provide...looks like a user error so far since I can't find any NIM's relating to this issue so far
JoeLenon
The file is located in C:\ArcGIS\GIS__Introduction\8_Raster_Analysis\8_Raster_analysis\house
The output raster is actually temporary but it doesn't work either when i specify a path.
Hope this would enlighten you.
BradenBurkholder
For future reference: It looks like there's a restriction on the path length with spatial analyst.  Use a shorter or temporary path name, e.g. C:\GIStemp.
I had these same errors and this fixed it.
Edit:  also select the features of interest prior to executing the command
manmade
Do you know how simple is it to calculate distance
online: Check for online 'Postcode distance calculator UK' in goole, it will help you to get exact
solution.
postcode.org.uk
It is working in all over Europe and is expanding its services
