Display A Slope Raster
7658
11
03-13-2020 02:44 PM
JoeBorgione
ArcGIS Pro 2.5
This is new territory for me; I haven't created surfaces since ArcInfo 6.x with TINs....
I have a number of tif rasters that I am attempting to create a slope analysis from.  I think I've created what I want, but I don't understand how to display it in a map.  Basically I want to show slopes less than 25% in green, 25%-35% in yellow and anything greater than 35% in red. See screen capture below.
I took a look at https://community.esri.com/message/895485-re-slope-percent-symbology?commentID=895485#comment-895485  but it applies to ArcMap, and I don't see a clear correlation to ArcGIS Pro.
The original tif raster has elevation in meters, hence the range of 1681-2050.  Using the Spatial Analyst tool box, I just used the Slope geoprocessing tool; entered my input raster, output raster, setting my output measurement to Percent Rise.  So far so good.
Choosing Classify as the 'Primary symbology' scheme, I can only set the number of breaks; what are the units it is displaying? How do I display my slope raster described above?
curtvprice
Joe, to answer your question directly about percent units, the units of slope are rise over run. If the DEM is in geographic, your slope values are invalid and really really high because the x is in degrees (makes no sense) and the y is in meters or feet.  The way to fix this is to project the raster to a projected coordinate system like UTM, so units in x and y are the same. May not be your issue, but I thought I'd add that to the thread.
JoeBorgione
Thanks Curtis; I don't have the data open at the moment, but it should be all utm and meters.  The elevation values make sense in that respect.
