DEM Artefacts
10184
12
03-05-2015 12:49 PM
PaulHeersink
I have a collection of data points from which I am trying to generate a DEM and, ultimately, a hillshade for use as a backdrop in a map. Whichever way I try to process it (using Topo to Raster) I get artefacts where the points are located. See the attached example:Capture2.JPG
Any ideas what might be causing this?
RajinderNagi
Dan, It seems the article you referred is from tech support and I added comment for them to update this for 10.x.
For any continuous surface, bilinear or cubic re-sampling should be used instaed of default nearest neighbor to avoid artifacts (such as stair case).
DanPatterson_Retired
thanks for updating the thread with the information... still no update but the link will be useful because of the image documentation
DEAF_PROBERT_68
Honored Contributor
Does the DEM you have are in known projection rather than geographic coordinate systems ? I'd check on that ..
