Creating a Depressionless DEM - Finding Sink Depth Problem
3227
01-21-2012 01:11 PM
JohnKerkering1
Hello,
My DEM (SRTM 90m) has sinks, as made clear by the output of the Flow Direction and Sink tools. I can fill these sinks with the Fill tool with no problem.
But I wanted to take a more precise approach by following the "Finding Sink Depth" process as outlined on the page, "Creating a Depressionless DEM". I followed each of the 5 steps outlined and determined that the maximum sink depth was 33 meters, as the output of the Minus tool ranged from 1 to 33.
I ran the Fill tool on the original DEM and specified a z-limit of 33 and then ran Flow Direction on this output. The Flow Direction output was the same as the Flow Direction output from the original, un-filled DEM. In other words, the "Finding Sink Depth" approach didn't work, unless I missed a step or made a mistake somewhere in there.
Anyone encounter a similar problem? Any thoughts or guidance would be most welcome.
Thanks.
CharlesMorton
Were you able to resolve this issue?  I am having problems with the Fill tool not changing values, but only when I set a z-limit value.  Your issue may be related to this.
Charles
WesKing
I believe this is still a bug that hasn't been fixed yet (at least the last I looked).  See this thread...
http://forums.arcgis.com/threads/31888-Hydrology-Flow-Direction-tool-output-quot-incorrect-quot-when...
Wes
PavanYadav
Wes
Hi All,
I have posted a comment on the above forum thread. In the above thread there is a discussion on a known bug (bug ID NIM069368). A fix for this bug is in our Service Pack 4 target list. SP 4 is planned to be available next month (March, 2012).
Thank you.
Pavan
Pavan Yadav
Product Engineer at Esri
AI for Imagery
Connect with me on LinkedIn!
Contact Esri Support Services
IlanHavinga
Hi Pavan,
Was this issue resolved? It appears I am having the same issue using ArcMap 10.5.1. Applying the maximum depth figure from the MINUS tool output as the z value in the Fill function only produces the same as running the Fill tool without it.
Ilan
