Create a network (or pipe flow direction) from contour layer?
691
06-03-2011 10:36 AM
ToddGraves
I have a general pipe layer. Is there a way to use a contour layer alongside this pipe layer to create a general flow model for the pipes? Each network generally has higher elevation points for the arcs and lower elevation points for the exit. It seems these could then delineate high to low flows in these smaller networks.
todd
