Combine tool unable to create new grid
1976
7
09-08-2011 11:55 AM
JontyKnox
Hi there, I am trying to use the combine tool on two raster grids but I keep encountering this error when I run the tool:
Start Time: Thu Sep 08 15:44:30 2011
An error was encountered while executing Combine.
("esriGeoAnalyst.GridEngine") Unable to open VAT file of C:\DOCUME~1\JONTY\LOCALS~1\TEMP\RASTER4
Error in executing grid expression
Failed to execute (Combine).
End Time: Thu Sep 08 15:44:30 2011
I have tried building a new VAT using python download from: http://arcscripts.esri.com/details.asp?dbid=13593
But this doesn' seem to work either. Finally in the error it states it is unable to open VAT file from: C:\DOCUME~1\JONTY\LOCALS~1\TEMP\RASTER4 I have checked and double checked and this file does not exist in my temp folder...
I really appreciate some help on this one as it has me completely stumped.
DianeMcConnaughey
Did you find a solution for this?  I will be combining rasters soon and fear the worst.   In 9.3.1 , it seems to work fine, but I have to rejoin the descriptive attributes.    I just tested in 10 SP2 set up on a remote server.  Slow, but it seemed to complete without error.  I still need to rejoin the attributes.  I have encountered problems with disk space, as well as environment settings for the tool and network/system errors which sometimes give misleading error messages.
JontyKnox
Unfortunately no solution as of yet. Still the same problem occurring even after adjusting the environmental settings.
DanPatterson_Retired
Grids should never be housed in a folder with spaces.  Check that as the root problem first.
JontyKnox
Hi Dan, While I did check for spaces there were none. The problem ended up being a memory indexing issue and is sorted now. Thanks for the help.
ShivaniAserkar
Hello, Can you please explain how you sorted this issues as I am having same problem and is uanable to create any combined rasters. I am trying to add 7 rasters which were further sliced from the original one. Shall appreciate your reply.
Thanks
SA
AnuragSinghai
AnuragSinghai
Thanks
SA
Hi Shivani,
This article may help:
http://support.esri.com/fr/knowledgebase/techarticles/detail/39783
