Combine Rasters using Con Expression - Error
1654
7
06-13-2012 06:37 AM
JannaCaspersen
I am trying to combine many rasters together to create 1 raster with all the input raster values added together. An example of the expression is below...
Con(IsNull("murle_ras_7"),0,"murle_ras_7") + Con(IsNull("murle_ras_6"),0,"murle_ras_6") + Con(IsNull("murle_ras_5"),0,"murle_ras_5") + Con(IsNull("murle_ras_4"),0,"murle_ras_4") + Con(IsNull("murle_ras_3"),0,"murle_ras_3") + Con(IsNull("murle_ras_27"),0,"murle_ras_27") + Con(IsNull("murle_ras_26"),0,"murle_ras_26") + Con(IsNull("murle_ras_25"),0,"murle_ras_25") + Con(IsNull("murle_ras_24"),0,"murle_ras_24") + Con(IsNull("murle_ras_23"),0,"murle_ras_23") + Con(IsNull("murle_ras_21"),0,"murle_ras_21") + Con(IsNull("murle_ras_20"),0,"murle_ras_20") + Con(IsNull("murle_ras_2"),0,"murle_ras_2") + Con(IsNull("murle_ras_19"),0,"murle_ras_19") + Con(IsNull("murle_ras_18"),0,"murle_ras_18") + Con(IsNull("murle_ras_17"),0,"murle_ras_17") + Con(IsNull("murle_ras_16"),0,"murle_ras_16") + Con(IsNull("murle_ras_1"),0,"murle_ras_1")
I also set the environments with a full extent and a specified cell size. The 000539 Error keeps appearing telling me that it "Could not save raster dataset to... with output format GRID.
Does anyone know how I can get around this?
DanPatterson_Retired
the error message indicates that you might be concatenating a string with a number
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00vp00000007000539.htm
JannaCaspersen
I looked at this page and I am not savy with python so I'm not exactly sure what you mean or how you are suggesting to fix it. Are you saying I need to take the numbers out of my file names?
JeffreySwain
What version of ArcMap are you using?  If you break it down to just running the top selection will it work?  If you are using 10, you may have to reference the raster differently.
outRas = Raster("inras1") + Raster("inras2")
From the help documentation here about accessing rasters.
SteveLynch
JannaCaspersen
I am using 10 and it does work if I run them in smaller groups of 2-5 but when I try to do them all at once it errors. I can go through and do it little by little but I will try the referencing method.
Luke_Pinner
MVP Regular Contributor
Did you look at the Cell Statistics tool Steve recommended? It does exactly what you are attempting to do with that long Con(IsNull()) code.
outCellStats = CellStatistics(["murle_ras_7","murle_ras_6","murle_ras_5","murle_ras_4",...,"murle_ras_N"], "SUM", "DATA")
FabianBlau
Check the output-name and location. The name has not to be to long for GRIDs (>13 characters). You may have a problem, if there are too many subfolders. Try something like "C:/outname.img".
