Color Model Conversion from RGB to HSV
9470
11-16-2010 11:05 AM
CaroFoehn
Hello,
I have a Tiff-file containing several bands, three of them beeing RGB. I like to convert them to HSV color model.
In 9.3 spatial analyst used to have the Color Model tools. I searched toolbox, resource centre, internet, but I coudn't find similar tools for ArcGIS 10. Did anyone find color model tools (that do not only apply to mosaic datasets) ?
Apreciate every help!
bye, lila
CaroFoehn
In the meantime I implemented a python script to do the color conversion manually, but it is very very slow. How can I make things more efficient? I won't have a chance to convert my final raster.
import arcpy
from arcpy import sa
import string
import numpy
import colorsys
arcpy.env.workspace = r"U:\path" # internal drive
inRast = r"U:\path\multiple_bands.tif"
outRast = r"U:\path\hsv"
Ymin = float(str(arcpy.GetRasterProperties_management(inRast, "BOTTOM")))
Xmin = float(str(arcpy.GetRasterProperties_management(inRast, "LEFT")))
Ymax = float(str(arcpy.GetRasterProperties_management(inRast, "TOP")))
rows = float(str(arcpy.GetRasterProperties_management(inRast, "ROWCOUNT")))
cols = float(str(arcpy.GetRasterProperties_management(inRast, "COLUMNCOUNT")))
# create numpy arrays
shape = rows, cols
hueArray = numpy.empty(shape)
satArray = numpy.empty(shape)
valArray = numpy.empty(shape)
x = 0
while x < cols:
    y = 0
    while y < rows:
        #Get the Cell values of the three bands
        values = arcpy.GetCellValue_management(inRast, str(Xmin + 5 + 10*x) + " " + str(Ymax - 5 - 10*y), "1;2;3")
        # save values in list
        slist = string.split(str(values), "\\", 3)
        b = float(slist[0])/255 # 1. Band Green equals blue in RGB
        nlist = string.split(slist[1], "n", 2)
        g = float(nlist[1])/255 # 2. Band Red equals green in RGB
        nnlist = string.split(slist[2], "n", 2)
        r = float(nnlist[1])/255 # 3. Band NIR equals red in RGB
        # convert ot HSV
        result = colorsys.rgb_to_hsv(r, g, b)
        hueArray[y,x] = result[0]*360
        satArray[y,x] = result[1]*100
        valArray[y,x] = result[2]*100
        y = y + 1
    x = x + 1
xymin = arcpy.Point(Xmin, Ymin)
hueRast = arcpy.NumPyArrayToRaster(hueArray, xymin, 10, 10)
satRast = arcpy.NumPyArrayToRaster(satArray, xymin, 10, 10)
valRast = arcpy.NumPyArrayToRaster(valArray, xymin, 10, 10)
satRast.save(outRast+"_sat.tif")
valRast.save(outRast+"_val.tif")
hueRast.save(outRast+"_hue.tif")
LouisZachos
This may help others who come across this:
The conversion tools for RGB to IHS and IHS to RGB are in the Toolbox : ERDAS Image Analysis Tools : Spectral Enhancement.
I have no clue where the old RGB to HSV, etc. tools went.
JeffreySwain
You mean the color model conversion function within Mosaic Datasets?  To complete the described process, you could use the mosaic dataset to create the look and then export it, or just utilize the mosaic dataset.  That would be the recommended way to create the color model change.  The mosaic dataset should be fairly fast, if your script is causing performance problems.
dsffdsdf
really help a lot if you use color conversion tool. it is easy to convert RGB color mode to HSV color model. but i can't tell whether it is fit for ArcGIS. hope it is the right image sdk control for you.
best luck
Lily
FionaGregory
I finally found Color Model Conversion under the Image Analysis window in ArcMap (10.2.2). Highlight your image name at top of window ->Processing->fx->Right click on Identity Function -> Insert->choose Color Model Conversion from list.
However it would not run on my 4 band Tiff. I don't know if this is because it is 4 bands (no option is given to select which bands to use for the color model) or because of its format. No useful error message, it just says the inputs are inappropriate.
