Change values in table to no data
1702
10-01-2010 04:55 AM
CristinaMadrid
Hello!
I am quite new in ArcGIS. I am trying to do an interpolation of precipitation from a point shape that I have created using an XY table.
My problem is that I had to change the no data values in the original table to -9999 so when I created the point shape the program wouldn't transform it in 0.
Now I need to tell arcGIS that those points are no data, so it can do the interpolation properly.
I could solve the problem in two ways:
1. By changing the -9999 values in the attribute table into "no data". For this I have tried SETNULL but a raster is required.
2. By telling arcGIS that it should not use -9999 when I do the kriging.
Any ideas?
Please!
Thank you very much.
EricKrause
In the Attribute Table, use "Select by Attributes" in the Table Options pull-down menu.  Use the equation "X > -9999", where X is the field of your precipitation values.  This will select all points with values above -9999.  With those points selected, run the kriging tool; only the selected points will be used in the interpolation.
There are other ways of doing it, but I think that's the simplest.
CristinaMadrid
Cool thanks!
I have actually done it with the geostatistical wizard and then convert to raster.
Interpolation is great, but I got some negatives (unlogic for precipitation). I must convert those negatives in zero now. But don't know haow. Any ideas?
Thanks again!
