Can not produce Spatial Component Analysis Eigenvalue text
1523
04-17-2023 06:23 AM
AnthonyGreenish
Each time I try to produce an Eigenvalue text file when doing a PCA on a 4 band file, I either get an error message or the program crashes. What am I doing wrong? Thanks for your answers.
AnthonyGreenish
The error is 000864 (Output data file: The input is not within the defined domain. ERROR 000814: Invalid file type). The text file I am proposing to use is  "D:\GIS\Default.gdb\Principal4.TXT". Actually, I have tried all kinds of file names and locations without any luck. All I have managed to do is crash the program.
DanPatterson
MVP Esteemed Contributor
What is the error?
What is the path and filename to the output *.txt or *.asc file?
Principal Components (Spatial Analyst)—ArcGIS Pro | Documentation
... sort of retired...
AnthonyGreenish
