Calculating the direction of streams in a polyline shapefile
981
05-09-2012 03:31 AM
ChristosDomakinis
Hi everybody,
I have created a polyline shapefile that contains data about the streams in a hydrologic basin (such as stream order etc). The tools that I used from Spatial Analyst Tools > Hydrology in order to produce the resulting polyline shapefile was: DEM> Fill > Flow Direction > Watershed> Stream Order > Stream To Feature. My question is how can I calculate the direction for each line in the resulting Stream To Feature polyline shapefile?
I would apprecite it if someone could provide me with an answer.
Thank you
