Calcuating nearest point to a given point.
1873
12-07-2012 07:21 AM
NadeemQazi
[ATTACH=CONFIG]19790[/ATTACH]I am new in Geo Analysis. Please refer to attach image to understand my problem . I have two layers as shown in table of the content in the map attached. The one named as sewered areas has following fields :
FID,Shape,County,Name,AreaRef,AreaHect,Source,Audit Name,Audit Date,comment.
The one that is named as tank has following fields.
FID,Shape,Join_Count,Join_Cou_1,BUILDING_I,ADDRESS_PO,ED_ID,BUILDING_U,EAST,NORTH,
DERELICT,VACANT ,INVALID,Name, Shape_Leng,Shape_Area,COUNTY,NAME_1,AREA_REF,AREA_HECT, SOURCE,AUDIT_NAME,AUDIT_DATE, COMMENTS,NEAR_FID,NEAR_DIST.
the third layer called roads has following fields
FID,Shape,ROUTE_NO,LINE,Shape_Leng,RD_TYPE
I already have done it by drawing a single line between the point in sewered area and septic tank and measure the length of that line to give me the distance. however What I want is that when I click any where in my sewered areas layer i want to determine the distance between this point and all the tanks in for example 1 km radius. and i also want to check whether this tank is on the road or  not.
Any suggestion or direction to start the work?
EricRice
Esri Alum
See the Generate Near Table tool.
Best,
Eric
