Buffer Density Analysis
11763
13
08-08-2012 08:21 AM
MikeWissner
Hello All,
I am running an analysis to prioritize locations that have the highest buffer densities, ie places where many buffers overlap.  Any idea how to determine this?  I don't think it's feasible to separate each buffer into its own layer.
Any help would be much appreciated,
thanks,
mike
by Anonymous User
Not applicable
Mike,
I am not sure why you are having this problem.  I was able to get it to work.  However, I only have an arcEditor license so I do not have the feature to point capability.  To get the buildings to centroids I used the "points to centroid" tool in the xTools Pro extension that I have.  However, as far as I know this tool works the same as the features to point tool so I am not sure what is happening. I was able to convert it to raster without any problems.
The first one I did I used a cell size of 200 for the polygon centroids and I used a focal stats circular neighborhood of 1320 ft to get the 1/4 mile effect of the buffers.  Here is what it gave me:
[ATTACH=CONFIG]16803[/ATTACH]
I did a second one as well just for display purposes using the same polygon centroid raster and used a circular neighborhood of 5000 ft.
[ATTACH=CONFIG]16804[/ATTACH]
MikeWissner
Thanks for all your help Caleb,
I don't know where my issues are coming from, but I'll continue to troubleshoot.  I know that what you suggested is the logical answer, so I'll probably just start from scratch and try again.
best,
mike
MikeWissner
My problem is definitely in the conversion to raster.  I'm continually getting a result with ZERO raster cells from the points.
by Anonymous User
Not applicable
I do not know why that is happening to you.  I cannot imagine how frustrated you must be.  Sometimes, this usually only happens when I try to run spatial analyst tools, but I will repeatedly try to run a tool and no matter what it doesn't work.  When this happens I will open up a new blank mxd and add just the input data that I need and try to run the tool again.  And for some reason, sometimes it will work, even though I have done nothing different from when I tried in the original mxd (might be a bug in 10?).
So I guess if you haven't tried this already, I would try to open a blank mxd and just add your point file and try the point to raster tool again. If this does not work, I would contact Esri to figure out what is going on.  I hope this works. Sorry to hear you are having such bad luck!!
Caleb
