Hello everyone,
I'm using ArcMap 10.2.2. Taking into account the following assumptions:
we have 2 rasters (satellite images from different satellite platforms) of the same pixel size, same coordinate system, little bit misaligned, Snap to Raster environment variable is not defined
I apply a map algebra operation on them. Let's say I add them (arcpy.sa.Plus(raster1, raster2)).
The question is: based on what rule does the Raster Calculator algorithms choose which of the two input rasters the output raster will be aligned to.
Example:
Inputs: Raster1, Raster2
Map Algebra Operation: Raster1 + Raster2
Output: Result (aligned to Raster1)
Question: Why Result is aligned to Raster1 instead of Raster2, since I have not defined Snap to Raster environment variable?
The search I did in order to try to find an answer to that is based on ArcGIS online documentation, help tools inside ArcGIS desktop environment, gis.stackexchange, esri forum, as well as python files. In the latter case, I ended up dealing with built-in functions that are included in arcgisscripting.pyd where I don't have access.
I hope I stated the question clearly. Thank you
