Aspect to vectors/polygons
6336
8
11-07-2016 04:34 AM
LaszloKomaromi2
Hi all,
I was wondering if you could help me out with a specific issue. I have an aspect map that I would like to convert into polygons based on aspect colours (directions). It is needed for my research in which I am separating two glaciers. Any idea how I should get around this task in ArcMap?
Thanks in advance.
Laszlo
DanPatterson_Retired
You will have to classify you raster to a nominal scale rather than using the actual aspect values.  The symbology can be used to guide you.  You can only save an integer grid to a polygon file, using the Conversion Tools to do this, but the reclassification step is needed.
I am also moving this thread to its rightful home https://community.esri.com/community/gis/analysis/spatial-analyst?sr=search&searchId=09e7e10f-de81-4...‌ to facilitate getting proper comments
LaszloKomaromi2
Many thanks for your reply Dan. That means I have to use the actual directions instead of values which is obvious, I am just not sure which feature to use for that. My glaciers divide along a Northeast and Southeast aspect divide which makes this task easier.
The aspect raster is a floating point raster
http://desktop.arcgis.com/en/arcmap/latest/tools/spatial-analyst-toolbox/aspect.htm
you have to reclass it to an integer raster.  BUT just taking the int of the layer is going to yield you want too many classes. So, 0-15 degrees... call it 1, 15-30, call it 2... or whatever.  Then when you have it reclassed, you can convert that to a shapefile and reassociate the raw information summary with the polygons.  Don't start doing averages unless you are familiar with directional statistics (I have a blog post on it)
LaszloKomaromi2
That's great. I won't get started with averages. I don't think it is necessary as there is a clear divide between two opposing directions.For that reason I will simply classify the directions as N, NW, E, SE, S, SW, W, NW.
Thanks for your invaluable help.
LaszloKomaromi2
The Raster Calculator tool keeps on crashing, I just can't get it started. Is there any other way to reclassify/round up values through layer properties or maybe the round up tool?
why are you using the raster calculator to reclassify?  There are a selection of tools in Arctoolbox to do that
like Reclassify—Help | ArcGIS for Desktop
LaszloKomaromi2
Ok, I've got it. I used the Reclassify tool. Thanks.
could you mark the thread answered then so that others will know that resolution was done
