Original User: Greforb
I tried to do some calculations on solar radiation in ArcGis 10. I use the Area Solar Radiation tool, and no matter what settings I use, I keed getting the error: Failed to open raster dataset. I Tried doing it both in ArcMap and in Python, using the following command:
AreaSolarRadiation("K:/Raster/dem.img","45,0","2800","WholeYear 2009","14","0,5","NOINTERVAL","1","FROM_DEM","32","8","8","UNIFORM_SKY","0,3","0,5",'','','')
I get the full error:
File "C:\Users\Gis\Desktop\vg.py", line 7, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Functions.py", line 5953, in AreaSolarRadiation
out_direct_duration_raster)
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Utils.py", line 47, in swapper
result = wrapper(*args, **kwargs)
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\sa\Functions.py", line 5933, in wrapper
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\geoprocessing\_base.py", line 474, in <lambda>
return lambda *args: val(*gp_fixargs(args))
ExecuteError: ERROR 999999: Error executing function.
Failed to execute (AreaSolarRadiation).
From which it seems to be the out_direct_duration_raster which is causing the trouble. However, this is optional, so I don't get why. I tried giving it a path for the out_direct_duration_raster, which does not help either.
I also tried to do a repair of the installation because I read somewhere else here on the forums that that might help. No luck though!
Any suggestions are greatly appreaciated
