ArcMap Nibble losing attribute fields
1127
09-19-2022 10:04 PM
YakupNiyazi
I have raster data, I classified it using a decision table. After, boundary cleaning, and regional grouping I have a link filed, which refers to the original classification code. But when I run the Nibble function, the link or other fields disappeared, leading to the loss of the original ID for the classified zones. I am new to spatial analysis, so it will be great if someone with some experience tells me the right way to do it. Thank you.
DanPatterson
MVP Esteemed Contributor
I would think boundary clean, then nibble, then regiongroup would be the order.
the first two tools can effectively remove zones determined by regiongroup hence the loss of potential zones.
... sort of retired...
