ArcGis 10.1
1162
01-02-2013 08:57 AM
chrisfisher
Does anyone know, or know how to check, which kernel density function estimator the the kernel density tool in Spatial Analyst, uses? Is it quartic? If not, is there a way to make it quartic?
I've seen discussions of old versions using quartic, but couldn't find anything about recent versions.
Thanks for you help.
MarkBoucher
Honored Contributor
Check http://forums.esri.com/Thread.asp?c=93&f=995&t=98735.
Might be some answers there.
chrisfisher
I had checked there, but they are referring to versions 8.x and 9.x; was curious if anyone knew about 10.1?
EricRice
Esri Alum
Did you read, How Kernel Density Works?
"The kernel function is based on the quadratic kernel function described in Silverman (1986, p. 76, equation 4.5)."
-Eric
