Accuracy of interpolation methods
1676
04-13-2021 10:14 AM
OscarJF
Hi all,
I performed groundwater head contours using Natural Neighbor interpolation.
Based on my contour lines, I carried out some hydraulic calculations of my model domain. In order to assess these calculations, I am using error propagation of my observations.
How can I find out the values' accuracy of the obtained hydraulic heads in my interpolated contours.
Thank you all in advance,
Óscar Jiménez Fernández
DanPatterson
MVP Esteemed Contributor
Why was Natural Neighbors chosen as the interpolation method instead of something like kriging?
How Kriging works—ArcGIS Pro | Documentation
or from the geostatistical analyst
Empirical Bayesian Kriging (Geostatistical Analyst)—ArcGIS Pro | Documentation
... sort of retired...
OscarJF
Thank you for the answer and the links provided.
Actually I did not only used Natural Neighbor, but also Bayesian Kriging and IDW interpolations. I know that Kriging is considered the interpolation method with best predictions, but it showed very weird behaviors on my contours, so Natural Neighbor provided the best fit to my field observations.
But, in order to proceed with my calculations, I need to find out the accuracy of the Z-values in my interpolated contour lines. Does anyone have an idea?
Thank you in advance,
Óscar
