Implementing merge() in ArcPy map algebra
5320
05-01-2015 08:23 PM
The merge() function (which we've used for years in GRID, ArcView, and ArcGIS Desktop) simply doesn't exist in ArcPy map algebra.
I came up with a Python map algebra implementation (with some nice refinements from a friend on the Spatial Analyst dev team). Give it a spin and let me know if you are successful with it!
import arcpy
from arcpy.sa import *
arcpy.CheckOutExtension("spatial")
def Merge(raster_list):
    """Merge a list of rasters. The first non-NoData value found (cell by cell) is kept.
       Merge([raster1, raster2, raster3, ...])
    This is another implementation of ArcGIS 9x Map Algebra merge() function"""
    if type(raster_list) == str:
        raster_list = raster_list.split(";")
    if len(raster_list) < 2:
        raise Exception("More than one raster required")
    # create list of raster objects to merge
    rlist = [Raster(arcpy.Describe(ras).catalogPath) for ras in raster_list]
    merge_ras = rlist[0]
    for ras in rlist[1:]:
        merge_ras = Con(IsNull(merge_ras), ras, merge_ras)
    return merge_ras
Version history
Last update:
‎12-12-2021 03:40 AM
Updated by:
