Solution Deployment ArcGIS Pro 3.0 and Portal 10.8.1
2926
11
07-12-2022 03:24 PM
RyanTucker
How are we supposed to deploy solutions using Pro 3.0 and Portal 10.8.1?  Or we don't?
ChrisFox
We are not releasing a 3.x version of the Solution Deployment Tool add-in for ArcGIS Pro. As @ChristopherCounsell described we started delivering the new ArcGIS Solutions app with Enterprise starting at 10.9. In addition. at Enterprise 11.0 the ArcGIS Solutions app will be available with the base install of ArcGIS Enterprise. This will be the recommended way to deploy solutions in Enterprise moving forward.
For previous version of Enterprise (10.5 - 10.8.1) you will need ArcGIS Pro 2.x and the ArcGIS Solutions Deployment Tool add-in.
ChristopherCounsell
MVP Regular Contributor
 It appears that they have shifted from the solutions being an ArcGIS Pro 2.x add-in to deploy to portal 10.5-10.8.1, to instead be an ArcGIS Enterprise installable component from 10.9.
https://doc.arcgis.com/en/arcgis-solutions/latest/get-started/faqs.htm#anchor3
Given this shift and that add-ins for 2.x have to be rewritten for 3.x, I wouldn't expect ArcGIS Solutions add-in for Pro 3.0 anytime soon.
https://pro.arcgis.com/en/pro-app/latest/get-started/migrate-2x-to-3.htm
https://www.esri.com/arcgis-blog/products/arcgis-pro/announcements/whats-new-in-arcgis-pro-3-0/
There are some good articles/discussion above and around if you should migrate to Pro 3.0 or not and what the potential implications will be. Personally I will hold off for some of the reasons discussed. If I was a solo operator and working with ArcGIS Online, there would be less implications.
ChrisFox
RyanTucker
So I need to downgrade Pro to make this work with our current Portal environment. Ok thanks.
MiguelMartinezYordan
Why not?
ehovland5
I used the ArcPro Solutions Deployment Tool to change and add new domains for the Citizen Problem Reporter layers. How do you recommend we edit and add new domains for a solution now? Thank you!
ChrisFox
For Hosted Feature Layers you can add and modify domain values from the item details page:
https://doc.arcgis.com/en/arcgis-online/manage-data/define-attribute-lists-and-ranges.htm
ehovland5
Thanks Chris! For the ESRI Solutions, Citizen Problem Reporter hosted feature layer, there is no option to create a list or add new fields. It says the properties are inherited when I follow the steps in the link provided.
ehovland5
Hi Chris, I figured out the solution. The Citizen Problem Reporter documentation has been updated and now directs you to edit domains via the .csv file. Thank you for your help!
ronpalazzetti
Hey Chris,
I am in a similar situation as the OP.  I have downgraded to ArcGIS Pro 2.9.11 to deploy a solution with my 10.8 enterprise. However, I am having a hard time locating the ArcGIS Solutions Deployment Tool add-in.  It seems all of the original links to the tool direct to the current form of Solutions, which assumes the enterprise 11 workflow.
Do you have any idea where I can locate the installer for the add-in?
