Road Closure Solution Issue
493
06-26-2026 11:00 AM
shaundaleigh
I am trying to deploy the Road Closure solution for my organization.  It deploys successfully but when trying to use the editor I am getting a multitude of console errors and the editing is very slow to load. Once it does load and I try to create a closure, the time field will not populate automatically. When I enter in values it does not recognize them as being entered and says value is required.
Joshua-Young
MVP Regular Contributor
Did you deploy the solution to ArcGIS Online or ArcGIS Enterprise? I believe ArcGIS Online was updated just yesterday. Either way, I would try signing out and then delete the site cookie for ArcGIS Online or Enterprise and your browser cache. I have not seen those specific errors before, but it looks like something is either unavailable or is being looked for in the wrong location which old cookies or cache could cause.
"Not all those who wander are lost" ~ Tolkien
shaundaleigh
Thank you for your reply.
It's deployed to ArcGIS online and was working yesterday as expected. I have removed the deployment, reinstalled, I have cleared my cache, I have run it incognito mode and tried on a machine that is not connected to our firewall and the issue persists.
Sounds like it is related to the update.
Joshua-Young
Based on what I am seeing on Esri Community, I expect it is more of an issue with the ArcGIS Online update than the deployment of the solution. If you have not already done so, I would recommend opening a case with Esri Support for the issue so they can start working on a fix.
ScottOppmann
@shaundaleigh  - I just deployed the solution and created a few closures.  Did not get any errors.
I would concur with Joshua, this issue could have been caused during the ArcGIS Online update late last week.  Could you please try deploying the solution again and adding a closure?
If you continue to get an error, please log the issue with Esri Support Services so it can be tracked and we can make sure you get a resolution.
shaundaleigh
Hi Scott, it has been discovered to be a bug relating to the ArcGIS Online June update.
https://support.esri.com/en-us/bug/arcgis-online-map-viewer-loads-the-edit-pane-slowly-whe-bug-00018...
