Need help: wmx parameters in ArcGIS Workflow Manager Post Installation
4316
11-11-2013 05:22 AM
by Anonymous User
Not applicable
Original User: VivekGaikwad2013
Hi All,
I am a new user to ArcGIS Workflow manager, I have the following application Configuration. We have existing sde services and I wish to configure ArcGIS Workflow Manager application.
ArcGIS Workflow Manager 10.1 Desktop
ArcSDE: 9.3.1.562
RDBMS : ORACLE 11g
I am following esri Best Practices for Storing the ArcGIS Workflow Manager Workspace in an Enterprise Geodatabase for Oracle White Paper. We successfully completed Step 2 and now I have certain issues in Step 3 procedure. I exported my existing dbtune_exp.sde. I am not able to understand these following steps.
Create a new DBTUNE keyword following the steps below:
 Copy the ##DEFAULTS keyword and paste it at the end of the dbtune_wmx.sde file.
 Rename it ##WMX and change the tablespace name for the appropriate parameters.
For above steps, I edited my dbtune_exp.sde fiile, I pasted the ##wmx (##wmx to END)content at the end of the file given in the white paper as saved the file as dbtune_wmx.sde and successfully imported the  dbtune_wmx.sde file. I hope the steps I did are correct. For reference I have attached my dbtune_exp.sde and dbtune_wmx.sde file.
When I ran ArcGIS workflow Manager Post Installation after entering instance and go to next part, I selected "Use Configuration Option" Dropbox, I am not able to find my wmx parameters. Pleas find enclose print screen snap.
I am not able to understand the reason, Is my dbtune_wmx file in which I enter is wrong or is there any other issue because of that wmx is not highlighting.
Need help.
Kind Regards
Vivek
vivekk.gaikwad@gmail.com
by Anonymous User
Not applicable
Original User: nmishra
Hello Vivek,
1. Open ArcCatalog, connect as Workflow Manager user, and try to create a new feature class, in the configuration keyword drop down, if the wmx configuration keyword does not show up then the dbtune is incorrect.
2. Do not copy the white paper ##WMX dbtune example, instead the you must copy and paste ##DEFAULTS to the end of the exported dbtune text file, don�??t forget to rename ##DEFAULTS with ##WMX or it will not show up in the configuration keyword drop down of the Workflow Manager Post-Install, then modify the tablespaces names in the ##WMX configuration keyword.
3. The sde configuration keyword dropdown does not appear in the �??Use Configuration Option�?� part of the WMX Post-Install.
Hope this helps,
Nishi
VivekGaikwad1
Hi Nishi,
Thanks a lot for responding to my query. as I understand have to copy the content from ##default to END and paste it at the end of the file as will save file as dbtune_wmx.sde. In the file for example :I have to modify the tablespaces names under ##WMX XML_IDX_STORAGE            "TABLESPACE CVE_INDEX PCTFREE 0 INITRANS 4", So I will change CVE_INDEX to WMX_INDEX, am I correct.Please suggest.
Could you please check my sde file and suggest the necessary changes.
Thanks & Regards
Vivek
by Anonymous User
Not applicable
Hi Nishi,
Thanks & Regards
Vivek
Hello Vivek,
Yes you do need to replace "CVE_INDEX" by "WMX_INDEX". However, if followed the white paper recommendations you need to create many other tablespaces, e.g. WMX_BDATA, WMX_BINDEX, WMX_SDATA, WMX_SINDEX, WMX_FDATA, WMX_FINDEX, WMX_ADATA, WMX_AINDEX, WMX_DDATA, WMX_DINDEX, then replace the tablespace for each configuration keyword properly as showed in the white paper dbtune example.
Hope this helps,
Nishi
UjjwalNigam
Include the UI_TEXT keyword as one of the ##WMX keywords
