NAICS_EXT Descriptions
6061
11
07-12-2012 05:54 AM
RobertWachal
I am trying to track down the NAICS_EXT code descriptions included in the infoUSA data shipped with BA. Does anyone know where might I find this information?
Jason_RobinsonRobinson
Robert,
I checked and looked like the 2011 InfoGroup Business Listings Data Description document is almost finished and should contain the information you need.  You will find it at the below link when it is released.
http://support.esri.com/en/knowledgebase/product-announcements/list/productid/153
You might want to take a look at the 2010 version just to make sure that it contains the information you are seeking.
Regards,
Jason R.
Robert,
Regards,
Jason R.
Robert,
Looks like the 2011 version just went live today.  Below is the link to the Resource Center where you can access it.
http://support.esri.com/en/knowledgebase/product-announcements/view/productid/153/metaid/1893
Regards,
Jason R.
DanielKnoepfle
Are there descriptions available for the 2010 and 2011 versions like posted here?: http://forums.esri.com/Thread.asp?c=154&f=1658&t=185984
The Data Description PDFs don't contain the descriptions for the 8-digit NAICS codes given in NAICS_EXT.
Dan
Dan
Dan,
Unfortunately this document is not available for posting publicly but I can provide it to you directly.  I see that you have private messaging disabled.  If you go to Settings>User Control Panel and enable Private Messaging we can sort this out.
Regards,
Jason R.
DanielKnoepfle
Jason,
I've enabled Private Messaging.
Dan
AmanTandias
Dan,
Regards,
Jason R.
Hi Jason,
I would like a copy of the NAICS_EXT descriptions as well. Why doesn't Esri just make this document available?
Thanks.
Aman
ShirongZhang
Hi friend,
I also want a copy of the NAICS_EXT file. Would you please give me a copy? Thanks a lot!!
Shirong
ShirongZhang
Hi Jason,
Thanks.
Aman
Hi Aman,
Have you got the copy? I also need it now. Can you send it to me as well? Thanks!
Shirong
ShirongZhang
Jason,
Dan
Hi Dan,
Do you still have the copy? I also need it now. Can you send it to me as well? Thanks!
Shirong
