Lead Service Line Solution - Utility Status Domain
2411
06-17-2024 06:44 AM
CarynAshbay
Using the lead service line solution.
My domains for "Customer Status" and "Utility Status" have the following options: Unknown, Lead, Non-Lead, and Galvanized Requiring Replacement.
When I use the domain in a filter widget for the "Utility Status" in Experience Builder, it pulls a completely different domain (see screenshots). "Customer Status" works perfectly well.
Has anyone else experienced this issue? What am I doing wrong?
Thank you!
AlexKabak
Hi Caryn,
A similar post was made regarding this issue by another user. Please see my solution to their post, as I believe it applies to your situation as well. https://community.esri.com/t5/water-utilities-questions/lead-service-line-solution-public-map-table/...
bsanders69
What does the Domain look like? This perhaps?:
Lead
Lead-lined galvanized
Galvanized
Non-Lead - Copper
Non-Lead - Plastic
Non-Lead - Other
Unknown - Likely Lead
Unknown - Unlikely Lead
Unknown - Unknown Material
This list is a change from EPA to the Detailed Inventory form for both the System side classification (status) and the Customer side complicating the symbology at the least. Not sure if this is your issue or not...but I had to make this change(and several others) manually in order to be able to populate the newly updated Spreadsheet mandated by EPA. Not sure if it ever got into a later version of this Solution as I am stuck in 10.9.1 Enterprise world for the foreseeable future and unable to upgrade this solution.
