GIS Request Management - Business Unit select_one not working
959
09-26-2025 03:30 AM
OliverIshmael
In the GIS Service Request Survey123 XLSForm I have defined the BusinessUnit choices as:
On the Survey tab this is defined as:
In the Survey123 Connect app, this displays correctly:
And yet on the ArcGIS Hub - GIS Service Portal page where I can submit a request - the form there doesn't work. The only option I have is 'Other':
How can this be corrected?
Joshua-Young
MVP Regular Contributor
Did you publish the updated form in Survey123 Connect?
"Not all those who wander are lost" ~ Tolkien
Joshua-Young
DanielWickens
@OliverIshmael - Like Josh mentioned, check to see if you've published the survey in Survey123 connect. Also, double check that the syntax of the list_name on the choices tab matches the select_one {list_name} on the survey tab.
OliverIshmael
School-boy error! Thanks for getting in touch
