Extract roof forms script error
1129
11-18-2021 07:33 AM
p_christov
Hello,
I'm trying to extract the buildings from a point cloud and get the following error:
Adding roof form field domain...
DescribeData: Method domains does not exist
Error on line 2363
Error in file name: C:\temp\3DBasemaps\scripts\bm_common_lib.py
with error message: AttributeError: Object: Error in parsing arguments for Exists
Failed script Extract Roof Form...
ERROR:root:Error on line 2363
I think this is because of this part of the script "extract_roof_form.py" (lines 2363 and 2364):
 if arcpy.Exists(output_fc):
 arcpy.ClearWorkspaceCache_management()
because Clear Workspace Cache only works with enterprise geodatabase workspaces.
When I commented line 2364 I was able to complete the task without errors. But this not always works.
I'm using ArcGIS Pro 2.8 and the latest solution. Any help will be appreciated.
Best regards,
Peter
GISgis3
I am having the same issue.  I'm on version 3.0.1.
Any progress on this.
