Extract Roof Form Error 3d Solution
988
12-16-2024 07:08 AM
CliftonGreene
Hello,
I'm working on a project for school where I need to recreate a coloroized LiDAR point cloud and am using the Solution walk through. I have created the DEM, DSM, and nDSM but once I attempt to create buildings at the first step it fails after a few seconds and I cant figure out why. I think there may be a coding error that it keeps running into but I'm not sure how to soleve it.
Extract Roof Form
Tool Path
C:\Users\Bigre\OneDrive\Documents\ArcGIS\Solutions\CreateBuildings.tbx\ExtractRoofForm
Parameters
Buildings     SEAFPnew
Elevation Surface (DSM)     SEA16_dsm_surface
Ground Elevation Surface (DTM)     SEA16_dtm_surface
Normalized Elevation Surface (nDSM)     SEA16_ndsm_surface
Create Flat Roofs Only     false
Minimum Flat Roof Area     250
Minimum Slope Roof Area     75
Minimum Roof Height     8
Output Building Polygons     C:\Users\Bigre\OneDrive\Documents\ArcGIS\Solutions\3DBuildings.gdb\SEA_BLDG
Simplify Buildings     true
Simplify Tolerance     0.1
layer1
first_time     false
previous_layer     SEAFPnew
first_time_dsm     false
Messages
Start Time: Monday, December 16, 2024 3:05:19 AM
ArcGIS Pro version: 3.4
Project Home Directory is: C:\Users\Bigre\OneDrive\Documents\ArcGIS\Solutions
Shapefiles are not supported. Please copy to a geodatabase.
Input data is not valid. Check your data.
Error on line 2393
Error in file name:  C:\Users\Bigre\OneDrive\Documents\ArcGIS\Solutions\scripts\bm_common_lib.py
with error message:  AttributeError: Object: Error in parsing arguments for Exists
Failed script Extract Roof Form...
Failed to execute (ExtractRoofForm).
Failed at Monday, December 16, 2024 3:05:21 AM (Elapsed Time: 2.42 seconds)
NickPopovich
Clifton,
We are glad you are exploring using this tool. From the error log it looks like you have an issue: "Shapefiles are not supported. Please copy to a geodatabase."
All of your data must be contained within a GeoDatabase for the tool to function properly. By default the paths are always set to create the data in a local geodatabase on your computer. Did you download the sample dataset and run the tools? That would give you an example of what the geodatabase would look like.
Let us know if this fixes your issues.
Thanks
Nick
