Electric Distribution Data Management solution for ArcGIS Enterprise?
1262
12-06-2023 05:05 AM
MennoTerBals_GIS4C
Good morning,
For a new customer we're deploying several ArcGIS Solutions to get them started with ArcGIS. It's a utility company on a Caribbean island and they're managing electric, water, sewer and telecom networks. For the latter three domains there are Data Management solutions for ArcGIS Enterprise, but for electric distribution the data management solution is only available for ArcGIS Online. Is there a particular reason for this? Can we expect the Electric Distribution Data Management solution to be available for ArcGIS Enterprise in the near future?
Thanks and best regards,
Menno
GelisaJoseph
Menno,
The Electric Distribution Data Management (as well as our Gas Distribution Data Management) is not available in Enterprise due to technical limitations of these solutions using subtypes in an hosted feature service that do not work properly ArcGIS Enterprise and ArcGIS Pro. Due to these limitations it is only available in ArcGIS Online. Our team will continue to monitor and evaluate the options going forward but the solution will likely not go into previous version of ArcGIS Enterprise and would only be possible for newer releases of ArcGIS Enterprise.
MennoTerBals_GIS4C
Thanks Gelisa. Understood.
We're planning to implement the Data Management solutions in ArcGIS Enterprise, but instead of using hosted feature services we want to store the data in an enterprise geodatabase and publish as referenced feature services. For the web maps and web apps the plan is to modify the service URLs with ArcGIS Online Assistant as far as possible. Worst case, we'll need to (re)create maps and apps.
