Desire Lines Error
3456
04-11-2013 12:12 PM
BillFearrington
Every time I try to create drive distance desire lines in BA 10
I get an error message "Error While Executing DesireLines Builder."
However, I am able to create straight line distance desire lines.
Any suggestions?
Jason_RobinsonRobinson
Any suggestions?
Bill,
First I would suggest testing Create Spider Diagrams (Desire Lines) using the sf_stores and sf_custs tutorial data (by using Store and Customer setup respectively and will be located at C:\ArcGIS\Business Analyst\US\Datasets\Tutorial).  If this fails also then you might have an issue with the install.
Over the years I have found that when using the drive time or drive distance option with Desire Lines that it can fail due to the input point features especially if there are a lot of records but it is dependent on the system so there is no hard and fast limit/rule.  What is the size of the data that you are working with?
Regards,
Jason R.
GrantMullins
Having the same thing happen too.  For me this has started since the latest 2012/17 update.
Grant,
Does this happen even with the Business Analyst tutorial data from my post above?
Regards,
Jason R.
