Crime Analysis Tool - Import Records Error
1124
02-27-2020 02:18 PM
RickeyFight
I am trying to use the Crime Analysis | ArcGIS Solutions for Local Government and I keep running into an error.
I am using these tools: RecordImportLG.zip
And following these instructions: Configure records import - Crime Analysis | ArcGIS Solutions for Local Government
I run the Configure Record Import (XY) tool. Then I select the .ini file in the Import Records tool.
For some reason I keep getting this error:
 File "C:\2018-10-31 Crime Analysis\import_records.py", line 1465, in <module>
 main(*argv)
 File "C:\2018-10-31 Crime Analysis\import_records.py", line 861, in main
 with open(rptLog, "w") as log:
OSError: [Errno 22] Invalid argument: 'c:\\2018-10-31 Crime Analysis\\logs\\2020-02-27_13-30-33_name".log'
 Failed to execute (ImportRecords).‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Suggestions for a work around?
DanPatterson_Retired
is it supposed to have the solitary "  before .log' ?
