Arcpy, create store layer, location of locator
3308
09-22-2011 06:30 AM
TylerCopple
Hello,
I'm extremely new to Arcpy and GIS in general but not to programming. I'm trying to walk through this example:
Create Store with Address Data
However, I cannot find
"C:/Program Files/ArcGIS/Desktop10.0/Business Analyst/Data/USA Geocoding Service/USA Geocoding Service"
in my installation. My BA installation path looks like C:/Program Files/ArcGIS/Desktop10.0/Business Analyst/Datasets, not /Data.
Did I forget to install something or is this example out of date?
Tyler
Jason_RobinsonRobinson
Hello,
Tyler
Tyler,
If you were the one that installed Business Analyst 10 there is an option to basically perform a data-less install. I would initially recommend running the install for Business Analyst 10 and make sure that 'Typical' option is used which should install the data on the local drive. I would double check and make sure how much hard drive space your primary drive has this will be installing a good 15+ GBs of data.
Regards,
Jason
TylerCopple
Tyler,
Regards,
Jason
Thanks Jason, I was able to go back to the installation package and extract the necessary files.
Tyler
