Address Data Management Split Intersecting Road tool errors when using ArcGIS Pro
6247
13
02-09-2022 01:47 PM
CochranBob
After updating to ArcGIS Pro 2.9.2 the the Split Intersecting Roads Attribute Rule no longer functions. It seems something was put in place to stop the iteration through split roads. When creating a new intersecting road I get the error message shown. the cut function. Anyone else having this problem?
RitaTaylor
I have never manually edited the tools before so I'm not sure where to find the script to edit. I'm assuming there is a file on my hard drive that I can edit with idle? Just don't know where.
Thanks for your speedy response. I appreciate any help I can get.
CochranBob
In ArcGIS Pro. Right click on roads centerline layer >> data design>>Attribute Rules. It is the split lines attribute rule.
RitaTaylor
Thank you.
RichardOwens
I am new to Pro and would like to get this tool to work with my current set of data.  Is there a way to use this tool with my current set of data without all of the other stuff that goes with it?  I just need the road split tool to split the centerline and then prorate the address range where the new intersecting road comes in.
Any help is appreciated!
