Address Coder in BA 2013
3747
02-18-2014 06:39 AM
PaulBreding
Trying to map some addresses using the Customer Setup dialog and get this error:
There is a known issue when using Address Coder with the Business Analyst 2013 dataset.  The Business Analyst team is working on fixing this issue as quickly as possible.
If you have access to the USA_ESRI_2012 dataset and switch BA to it then Address Coder will function as normal.
Address Coder will now close.
Any idea when this will be fixed?
Jason_RobinsonRobinson
Paul,
Yes this is actually fixed.  Patch was released late January.  Below is the link.
Address Coder 10.2.1 2013 Data Patch
http://support.esri.com/en/downloads/patches-servicepacks/view/productid/153/metaid/2063
Regards,
Jason R.
Paul,
Regards,
Jason R.
