Search Widget on 3.21
1843
09-13-2017 02:02 PM
SeanPhayakapong2
Am I missing something for my Search Widget? I am trying to customize the widget to search feature layers, but it only recognizes Integers and not String values. I believe my problem stems from my organization's configuration of its REST server. Any help is appreciated. I am running this in CMV 2.0.0beta2
define([
      'esri/tasks/locator',
      'esri/dijit/Search',
      'esri/layers/FeatureLayer',
      'esri/InfoTemplate',
      'dojo/has',
      'dojo/domReady!'
], function (Locator, Search, FeatureLayer, InfoTemplate, has) {
return {
   map: true,
   mapRightClickMenu: true,
   enableInfoWindow: true,
   enableButtonMode: has('mobile') ? false : true,
   expanded: true,
   enableSuggestions: true,
   allPlaceholder: 'Find an address or APN',
         sources: [{
            placeholder: 'Find an address',
            locator: new Locator('http://gis.ci.oceanside.ca.us/gis/rest/services/AddressLocator_Composite2016/GeocodeServer'),
            singleLineFieldName: 'SingleLine',
            outFields: ['Loc_name'],
            localSearchOptions: { minScale: 300000, distance: 50000 }
            featureLayer: new FeatureLayer('http://gis.ci.oceanside.ca.us/gis/rest/services/WebService/Parcel/MapServer/0'),
            searchFields: ["APN"],
            name: "Assessor's Parcel Number",
            displayField: "APN",
            exactMatch: false,
            outFields: ["*"],
            placeholder: 'APN - ex 1470950400',
            maxResults: 6,
            maxSuggestions: 6,
            minCharacters: 0,
            infoTemplate: new InfoTemplate("Search result", "APN: ${APN}"),
RobertScheitlin__GISP
You would probably be better off have this question in the https://community.esri.com/groups/cmv?sr=search&searchId=98b152a5-0997-4a19-a16a-76d8ffce0bab&search...‌ group
RebeccaStrauch__GISP
I will move it.
TimMcGee1
While the application is using CMV, the configuration is for the Esri Search widget which can be used within CMV and elsewhere. You can test your Feature Layer(s) and Locator using this sandbox example for the Search widget: ArcGIS API for JavaScript Sandbox
SeanPhayakapong2
Yes, that is why I did not put this in the CMV group. I think this is more of my organization's REST server, since I plugged in other REST servers's parcel data and they worked fine with the exact same code. I just do not know how to proceed within my organization/server setting.
My apologies for moving it too quickly.  You can move it back (or I can if needed).  Remember you can all tag other groups with the @ and the space/group name.
