scaling issue
3238
01-15-2016 07:18 AM
justinlandolt
I am new to the forums and and to arc. I am hoping you guys could help me out with my scaling problem in arc desktop basic. I have this scaling issue when i try to start a new map or work on a current map. as an example i have measured the top area of kingfisher county from blain to logan and it measures Line measurement (Planar) Length: 0.000101 Miles. Could it be the current projection that i am using or where i got the data? how can i correct this?
Thanks!
My current projection:
NAD_1927_StatePlane_Oklahoma_North_FIPS_3501
WKID: 32024 Authority: EPSG
Projection: Lambert_Conformal_Conic
False_Easting: 2000000.0
False_Northing: 0.0
Central_Meridian: -98.0
Standard_Parallel_1: 35.56666666666667
Standard_Parallel_2: 36.76666666666667
Latitude_Of_Origin: 35.0
Linear Unit: Foot_US (0.3048006096012192)
Geographic Coordinate System: GCS_North_American_1927
Angular Unit: Degree (0.0174532925199433)
Prime Meridian: Greenwich (0.0)
Datum: D_North_American_1927
  Spheroid: Clarke_1866
    Semimajor Axis: 6378206.4
    Semiminor Axis: 6356583.799998981
    Inverse Flattening: 294.9786982
KousikM
Justin,
I think you can change your Geographic Coordinate System as GCS_WGS_1984.
Mine as follows,
Geographic Coordinate System:GCS_WGS_1984
Datum:D_WGS_1984
Prime Meridian:Greenwich
Angular Unit:Degree
Also I have measured as which area you mention above and I have attached for you reference.
