Public Information Template - Template.js
1542
12-04-2014 01:48 PM
WalterDziuba
I've downloaded the public information template locally and have added my proxy settings etc. But when I fire up the web application, the app stalls and while using the developer tools, I see this error from the template.js file.
It states that the defaultTemplateConfig is not defined.
Walter
Tags (1)
KellyHutchins
Esri Notable Contributor
Walter,
I downloaded the Public Information template from github and set it up on my web server. Didn't make any updates and it ran fine. Can you test that to see if its something in the updates you made that might be causing the issue.
Kelly
WalterDziuba
Morning Kelly,
I did not download this template from GitHub, rather from the AGOL template download.
Will try your suggestion.
Walter
WalterDziuba
Kelly,
Saw where I trumped that variable. So, it's not the template at fault, but me.
Walte
