JavaScipt web map - local shapefile used as parameter to geoprocessing service
3622
09-18-2015 09:11 PM
AaronMielke1
Does anyone have an example of a JavaScipt web map that allows a user to upload a local shapefile to be appended to a feature class in a map service.  It seems like this is pretty straight forward.  I created a geoprocessing service using the append tool that works in the desktop environments. I am using the upload url to upload the zipped shapefile but don't know how to call that file so that it can be used in my GP services.  The GP service only has one input parameter.
Parameters:
Parameter: Input_Datasets
Data Type: GPMultiValue:GPFeatureRecordSetLayer
Display Name: Input Datasets
Description:Data to add to Action Areas
Direction: esriGPParameterDirectionInput
Default Value:
Parameter Type: esriGPParameterTypeRequired
Category:
            function upload()
                var upload = esriRequest({
                  url: "https://maps2013.barr.com/maps/rest/services/Magellan/Append/GPServer/Uploads/Upload",
                  form: dojo.byId("uploadForm"),
                  content: { f: "pjson" },
                  handleAs: "json",
                  load: displayResult,
                  error: uploadFailed
                upload.then(uploadSucceeded, uploadFailed);
