How to get LastModifiedDate of feature layer through Javascript api
2719
06-15-2017 07:29 PM
KamalMittal
I want to get LastModifiedDate or Last Edit Date of feature layer through javascript api v3.2. How do I achieve that?
Kamal
Tags (1)
RobertScheitlin__GISP
Kamal,
   For that you would use esriRequest to get the json result for the rest endpoint that you are picturing in your image.
require([
  "esri/request", ...
], function(esriRequest, ... ) {
  var layerUrl = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/0";
  var layersRequest = esriRequest({
    url: layerUrl,
    content: { f: "json" },
    handleAs: "json",
    callbackParamName: "callback"
  layersRequest.then(
    function(response) {
      console.log("Success: ", response);
  }, function(error) {
      console.log("Error: ", error.message);
Kamal,
   Are you saying that your feature layer has a field for LastModifiedDate or Last Edit Date?
KamalMittal
Please see attachment below
Kamal,
require([
  "esri/request", ...
    url: layerUrl,
    handleAs: "json",
  layersRequest.then(
KamalMittal
Thanks Robert. It works like a charm.
Can I achieve same thing through arcgis runtime iOS sdk v100.0 ?. I have put query related to this to new thread:
https://community.esri.com/message/694399-how-to-get-lastmodifieddate-of-feature-layer-through-ios-s...
Kamal
Kamal,
   Be sure to mark this question as answered. I don't know runtime stuff so some one there will have to answer that.
