How do I add World Street Map to my ArcGIS Server?
1797
12-13-2017 01:37 PM
JarrettLee
I'm trying to add the World Street Map basemap to my server, for offline usage. Is there supposed to be a way to download a file (mpk) of it?
I've also opened the map from World_Street_Map (MapServer) in ArcMap, then tried to share it as a service to my instance. But, when I try to Publish, I get error 00005, "Layer type is not supported". I don't know if it is my instance or if I'm not supposed to import the map that way.
I'm new to the ArcGIS world, so I don't know where I'm supposed to be looking. Thanks!
RobertScheitlin__GISP
Jarrett,
   If you need to use esri basemaps offline then you need to be looking at Portal on premise. No you can not just download a mpk of the esri street map.
