Disable vector tiles in ArcGIS API for JS Feature Layer
1209
10-28-2019 11:30 AM
DanielUrda
Hello,
I am trying to consume a Feature Layer published by ArcGIS Server 10.7 in an JS application using the ArcGIS API and server-side filtering. Unfortunately, this produces vector tiles by default and the performance on our test environment is horrendous. Using a plain Graphics Layer provides superior performance (i.e. esri JSON format), however I have to manually deal with querying the server and then assigning a style and injecting the features in the layer.
Is there any way (either in ArcGIS Server/ ArcGIS Online or preferably in the JS API) to disable the use of pbf format?
RoyJackson_AlertMedia
You can disable pbf using an after request interceptor, to remove pbf from the supported formats.
This will still get the data in json tiles.  I am looking for a way to disable tile-based requests for a featurelayer.
