chrome browser warning related to TLS 1.0 or TLS 1.1
1881
02-12-2019 09:11 AM
Pa_Lotus
Hi
I got the below message in chrome browser, how to resolve it
The connection used to load resources from https://maps.xyz123.com used TLS 1.0 or TLS 1.1, which are deprecated and will be disabled in the future. Once disabled, users will be prevented from loading these resources. The server should enable TLS 1.2 or later. See https://www.chromestatus.com/feature/5654791610957824 for more information.
Any suggestions
Thanks
RobertScheitlin__GISP
Pa_Lotus
does the services which are running already will affect by this update?
Thanks
If you have questions about the TLS patch you should direct them to esri tech support.
