Zoom between Tilepack scale levels
3153
09-12-2011 06:51 PM
MichaelErlich
When zooming in/out with tilepacks, is there any way to zoom between the tile image scale levels with shrinking/growing the tiles?
MichaelBranscomb
Esri Frequent Contributor
By default you should be able to zoom to any scale. There is a property on the Map called SnapToLevels which if you explicitly set to True will only allow you to zoom to the specific scales defined by the Tiled service / package.
Cheers
Mike
