WPF API - non runtime (3.0 vs 2.4)
4391
6
04-03-2012 11:18 AM
AngelGonzalez
The 2.4 version of the WPF API I was able to publish an application using clickonce and have users on my network use the app. Can I still do the same thing at 3.0 without have to use any licenses?  All references to any maps will point directly to ArcServer.
Thanks
MichaelBranscomb
Esri Frequent Contributor
If you are only using services from ArcGIS Server or ArcGIS Online that represents a "Basic" license in the new ArcGIS Runtime SDK for WPF (v3.0 of the API). You will need to set the license string, but at the Basic level the license continues to be free.
Cheers
Mike
AngelGonzalez
Thanks for the info.
One more question, can I install 2.4 and 3.0 Pre-release on the same machine and use 10.0?
Also if I only use ArcGIS Server layers/features in my 3.0 WPF application do I still need to use the deployment tool to deploy the app or can I still use Clickonce to deploy the app to our users in our organization (behind a firewall) as I currently do now.
Thanks.
MichaelBranscomb
Thanks.
Yes, you can install 2.4 and 3.0 Pre-release on the same machine but the default assembly references and toolbox UI components will be updated to v3.0.
If you only use ArcGIS Server layers you will still need to use the Deployment Builder but this does not actually deploy the app, it just helps you to create an ArcGIS Runtime deployment folder with the minimum components you need. If you're only using services then the ArcGIS Runtime deployment will be very small. You will still need to deploy the ESRI.ArcGIS.Client.dll assembly with your application (plus any other WPF client assemblies you use). ClickOnce deployment should work fine - please let me know as soon as possible if you experience any problems and we'll investigate.
Cheers
Mike
BrianLocke
Dragging and dropping Runtime Application works great, have it working against ArcGIS Server and can do a quite a few different tasks yet when I deploy via ClickOnce -- 😞 deploys and have alot of people using this application works great until I try to start a GeometryService-- getting this and have gotten of reports on about 10 machines so far
Log Name:      Application
Source:        Application Error
Date:          05/29/2013 10:01:10 PM
Event ID:      1000
Task Category: (100)
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      cfpa03gis.ODF.STATE.OR.US
Description:
Faulting application name: WRMS.exe, version: 1.0.0.0, time stamp: 0x51a6dcbc
Faulting module name: KERNELBASE.dll, version: 6.1.7601.18015, time stamp: 0x50b8479b
Exception code: 0xe0434352
Fault offset: 0x0000000000009e5d
Faulting process id: 0x6ea8
Faulting application start time: 0x01ce5cf2ad0160d3
Faulting application path: C:\Users\blocke\AppData\Local\Apps\2.0\WO9WVNVW.X30\K1H5434P.O2E\wrms..tion_a062cf3d3dbaacfb_0001.0000_2b6e0cc01b655b6e\WRMS.exe
Faulting module path: C:\Windows\system32\KERNELBASE.dll
Report Id: f1082f3c-c8e5-11e2-98a6-d067e544e921
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
  <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Level>2</Level>
    <Task>100</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2013-05-30T05:01:10.000000000Z" />
    <EventRecordID>26839</EventRecordID>
    <Channel>Application</Channel>
    <Computer>cfpa03gis.ODF.STATE.OR.US</Computer>
    <Security />
  </System>
  <EventData>
    <Data>WRMS.exe</Data>
    <Data>1.0.0.0</Data>
    <Data>51a6dcbc</Data>
    <Data>KERNELBASE.dll</Data>
    <Data>6.1.7601.18015</Data>
    <Data>50b8479b</Data>
    <Data>e0434352</Data>
    <Data>0000000000009e5d</Data>
    <Data>6ea8</Data>
    <Data>01ce5cf2ad0160d3</Data>
    <Data>C:\Users\blocke\AppData\Local\Apps\2.0\WO9WVNVW.X30\K1H5434P.O2E\wrms..tion_a062cf3d3dbaacfb_0001.0000_2b6e0cc01b655b6e\WRMS.exe</Data>
    <Data>C:\Windows\system32\KERNELBASE.dll</Data>
    <Data>f1082f3c-c8e5-11e2-98a6-d067e544e921</Data>
  </EventData>
</Event>
BrianLocke
Accompanied error with it
Source:        .NET Runtime
Date:          05/29/2013 10:01:09 PM
Event ID:      1026
Task Category: None
Level:         Error
Keywords:      Classic
User:          N/A
Description:
Application: WRMS.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.InvalidOperationException
Stack:
   at ESRI.ArcGIS.Client.Tasks.GeometryService.LengthsAsync(System.Collections.Generic.IList`1<ESRI.ArcGIS.Client.Graphic>, System.Nullable`1<ESRI.ArcGIS.Client.Tasks.LinearUnit>, ESRI.ArcGIS.Client.Tasks.CalculationType, System.Object)
   at WRMS.Framework.ViewModels.MeasureVM.<measure>b__4(ESRI.ArcGIS.Client.Local.LocalGeometryService)
   at ESRI.ArcGIS.Client.Local.LocalService.FailStart(System.Exception)
   at ESRI.ArcGIS.Client.Local.Internal.Requests.ProcessResponse[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](System.String, System.String, System.Exception, Boolean, System.String, System.Action`2<System.__Canon,ESRI.ArcGIS.Client.Local.Internal.RequestInfo>)
   at ESRI.ArcGIS.Client.Local.Internal.Requests+<>c__DisplayClass7`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].<Start>b__2(System.Object, System.Net.UploadStringCompletedEventArgs)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
   at System.Windows.Threading.Dispatcher.WrappedInvoke(System.Delegate, System.Object, Int32, System.Delegate)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Threading.ExecutionContext.runTryCode(System.Object)
   at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode, CleanupCode, System.Object)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
   at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
   at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
   at System.Windows.Threading.Dispatcher.InvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
   at System.Windows.Application.RunInternal(System.Windows.Window)
   at System.Windows.Application.Run()
   at WRMS.App.Main()
Event Xml:
  <System>
    <Provider Name=".NET Runtime" />
    <EventID Qualifiers="0">1026</EventID>
    <Level>2</Level>
    <Task>0</Task>
    <TimeCreated SystemTime="2013-05-30T05:01:09.000000000Z" />
    <EventRecordID>26838</EventRecordID>
    <Security />
  </System>
  <EventData>
    <Data>Application: WRMS.exe
Stack:
   at ESRI.ArcGIS.Client.Tasks.GeometryService.LengthsAsync(System.Collections.Generic.IList`1&lt;ESRI.ArcGIS.Client.Graphic&gt;, System.Nullable`1&lt;ESRI.ArcGIS.Client.Tasks.LinearUnit&gt;, ESRI.ArcGIS.Client.Tasks.CalculationType, System.Object)
   at WRMS.Framework.ViewModels.MeasureVM.&lt;measure&gt;b__4(ESRI.ArcGIS.Client.Local.LocalGeometryService)
   at ESRI.ArcGIS.Client.Local.Internal.Requests.ProcessResponse[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](System.String, System.String, System.Exception, Boolean, System.String, System.Action`2&lt;System.__Canon,ESRI.ArcGIS.Client.Local.Internal.RequestInfo&gt;)
   at ESRI.ArcGIS.Client.Local.Internal.Requests+&lt;&gt;c__DisplayClass7`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].&lt;Start&gt;b__2(System.Object, System.Net.UploadStringCompletedEventArgs)
   at WRMS.App.Main()
</Data>
  </EventData>
</Event>
BrianLocke
Is this something to do with the manifest and clickonce/Certificate ??? I am totally lost on this and have been trying to figure this out for quite some time?????
